4 Attachment(s)
New Ride Pads on the UL-1
I had suffered yet another episode of the "Bermuda" triangle , it happens with the Tactic and usually the boat stops, but it kept going and my poor depth perception was telling me that the boat was turning:o , my foot! So the first time it went into the reeds , no damage, the second time straight to the shore :frusty:.
I did not run the boat for a long time because the ride pad surface was terrible, the boat wobbles a lot, since I had to fix the hole on the sponson , I decided to put a simple ride pad made out of G 10 FG plate.
Sanded ride surface:Attachment 117501
Two strips of G 10 ride pads :Attachment 117502
Already filled hole, I used "finishing epoxy" mixed with West Marine 404 High_Density Adhesive Filler. I did not use Bondo or West Marine "MarineRX" because these materials don't work well on edges, they are great if you have vast expanse of territory, on corners and edges I found out they sometimes they will chip away a little:Attachment 117503
New "tips":Attachment 117504
