HPR C5009 upgrade - goal 105 mph
Hi there,
Im upgrading my HPR C5009 for the third time. Here´s a short presentation of the two earlier setups:
2 x leopard 4082 2000kv
2 x seaking 180a V3
Props: Octura X 2/446 (cut)
Max speed: 129,6 kph (80,52 mph)
2 x leopard 4082 X2 2200kv
2 x seaking 180a V3
Max speed: 140,9 kph (87,55 mph)
Same setup and ABC 1814 17 45; 155 kph (96,31 mph)
When use of ABC the setup is reaching its limit. ESCs cuts (thermal cut?). LVC is deactivated. The lipos are in SAW world record category, so they deliever enough power; SLS Quantom 65C and Roaring Top 80C.
Further plan of upgrade:
The seaking 180A has impressed me. But now Im beginning to experience that it could not handle bigger props. My next step was to go for ABC 1915, but ended up on 1817 - which is smaller, but has a pitch of 1.7.
Based on these new props, Im going for 2 x swordfish 240A datalog. I considered twin swordfish X 300A, but I think 240s should keep up. Will be interesting to test.
That beeing said. I have had a lot of fly offs after using ABC. So I will lower the drives a bit, and also have some more weight in front than earlier.
