hello OSE
has anyone found a replacement liner for the brass tube in the Voracity.
obviously they sell the flex shaft with a liner but is there another choice so I can use with my new OSE HD flex shaft ?
hello OSE
I run an OSE cable in my stock liner.
yes, I do as well. although the couple I have are worn and beginning to leak
Leak, meaning water in the hull through the stuffing tube? Some tricks I've used on that particular boat:
- try heat shrink or sealant at the joint where the stuffing tube mates with the strut
- using a little more grease inside the tube itself
- a small bit of silicone hose over the tip of the stuffing tube inside the hull, just large enough that it doesn't rub on the flex cable
- replacing the brass bushing in the strut with two new lead teflon bushings to close up the clearance on the prop shaft
