This FE boat ting is gonna be FUN.
Just took my AQUACRAFT MC out for its maiden run and all I can say is pretty damn cool boat,After days of research and and reading this forum for things to look for and correct on this boat, I can say was very well worth the time spent only real issue was flexcable to motor alignment, and no gap at strut, and loose motor mounts, and dry flexcable.Other than that everything else seems good to go,also running stock prop for now,Ran a couple venom 5000mah 30c packs for starters, boat looked to have decent speed without any adjustments to strut or rudder, was a balmy 34 degrees out so as far as esc and motor temps that will have to wait,only ran those two packs and I'm hooked on this FE boating,So if any of you guys new to boating are not sure of something search this forum and research before taking that boat out of the box and right to the water only to have a bad experience due to being in a rush to rip across the water.
