First run with all box stock settings with raw props and old batteries....Yea, I got soaked as well. Next run it'll have some good props on it. :popcorn2:
https://www.youtube.com/watch?v=bwkj...ature=emb_logo
Looks like a good play boat boat . How much run time are you going to try and get with it or are you going to send this one flying for speed .
Here is another run from today.....All stock boat (including the TFL two piece flex shafts) except for the Chris Hoffmann (dasboata) props. Not too bad for the 2nd time it ever hit the water. The next run will be on the back stretch of the lake with a little better batteries and props. Stay tuned....
Attachment 168905 Attachment 168906
https://www.youtube.com/watch?v=oOf0W2w76zw&feature=youtu.be
Finally had some halfway decent weather to try it out again in. So here's another quick run in windy conditions that officially puts my Zonda into the 100mph club. Still a pretty conservative setup with test props on the boat now and it should pick up a few more mph in a little better conditions with some premium props and a little better batteries in it...
Attachment 169267
https://www.youtube.com/watch?v=qMY_ZKYOLNw&feature=youtu.be
Here is another run hitting 106mph. ALL STOCK with Chris Hoffmann (dasboata) props. More to come....
Attachment 169365 Attachment 169366
https://www.youtube.com/watch?v=U_3BSQIQh5g&feature=youtu.be
Durability test.
https://www.youtube.com/watch?v=LUvWoZT8y28
Glad to see it landed right-side-up. As I mentioned in my YouTube comment, hope to be able to get one late this year, or early next year
Sent from my SM-N975U using Tapatalk
Here is my latest run making the TFL Zonda "The Worlds fastest RTR Boat" (running factory stock electronics). The boat hit 109.3mph by the gps devices and the props used were from Chris Hoffmann (dasboata). Big thanks to Banggood.com for sending me this Awesome boat to test and a BIG THANKS to Chris Hoffmann (dasboata) for the Awesome props! More to come!
Attachment 169624
https://www.youtube.com/watch?v=NrcqAJn_Qbw
Hey what’s up bud been following you on YouTube definitely know how to make the boats haul ass I was wondering what props are you running on that 36 miss Geico and what kind of batteries
Thanks Mike! The props on the Geico are a custom prop from Chris Hoffmann (dasboata) we call "Super Geico" props. You can look him up on here or email him at dasboata@aol.com. I Normally run 4-3s packs in the Geico anywhere from 4,000- 6000mah at least 50c. Steve sells some good Revolectrix packs in the OSE store as well. Take care.
SUPER ZONDA!!! NEW PB! The Worlds Fastest TFL 41" Zonda is now even faster and now The Worlds Fastest RTR Boat (running factory stock electronics). The boat hit 111mph by the logger and 110.8mph on BOTH gps devices. The props used were from Chris Hoffmann (dasboata).
https://www.youtube.com/watch?v=wblvcRkyfsg
Attachment 169729 Attachment 169730
That was awesome keep up the great work.
Just curious on the setup. Still running the two piece flexshafts? What was the prop size? ABC?s? Thanks
Verzonden vanaf mijn iPhone met Tapatalk
My flex shafts and abc props are both custom by Chris Hoffmann (dasboata on here) No specs are given on the props due to a few that wanted to disrespect us after my Zonda hit speeds that had never been achieved before in a RTR/ARTR boat. I ran the stock flex shafts to 106 or 109mph They did fine except for on one run a bullet nut set screw came loose and after that I swapped them out for the dasboata shafts. You can run abc props on the stock shafts and I know guys say you can't, but you can if you change out the large TFL drive dogs for the small octura dogs. By doing that it will allow more room for the longer hubs of the abc props.
Thank you for reacting! Appreciated. Will soon receive a Hydromarine Freya Cat. Will run it single motor.
Here is my latest run making the TFL Zonda "The Worlds fastest RTR Boat" (running factory stock electronics). The boat hit 113mph by the gps devices and the props used were from Chris Hoffmann (dasboata). More to come!
Attachment 172530
https://youtu.be/qhPVgpPIs18
First outing of 2021
https://www.youtube.com/watch?v=thKnFrRCk1k
nice pass Mark
Thanks Chris! Now its time to go to the big area to run....I've maxed this lake out and not enough room. The boat keeps pulling mph but I have to let off early. Should get a couple more mph fairly easily. Only need time now...
https://www.youtube.com/watch?v=bIsTzHLW7pI
Good work, takes some time and fine tuning but man you have it dialed!! Congratulations
The Worlds fastest TFL 41" Zonda (on stock electronics) hits 120mph+!! One gps got the boat at 120.7mph and 123.6mph on
the other. The osd datalogger got the boat at 119mph. As I let off the throttle the rudder snagged a limb and broke the rudder breakaway causing it to roll. I was able to dry the other
gps out and have a short video of that at the end. Huge thanks to Chris Hoffmann (dasboata) for the Awesome set of props!. More to come!
Attachment 173777 Attachment 173778
https://www.youtube.com/watch?v=wCGfGCw4P0Q
Massive congrats, I'd love to know the base prop that you started with, I know all the prop mods etc are top secret but what raw prop did you start with?
But the props are available to buy or whats the deal?
Here's a YouTube shorts video of a 118mph pass cut down. More to come!
https://www.youtube.com/watch?v=AIJrEs7hWak
