Good afternoon all.
I recently acquired an TFL Pursuit and was wondering if it?s better to run a single 4s in p limited or two 2s. A little help please. Boat is set up for single 4s currently
Good afternoon all.
First off, welcome to the OSE forum! I havent raced FE's for a while but no one else has chimed in so I'll take a stab at it. The less wire the less resistance. Either way can work. My P-Lim is configured for two packs however, I prefer to run two smaller 4S packs in parallel. If your CG is good with a single 4S pack, I'd keep it the way it is. Keep you wire lengths short if excessively long and get the best quality packs you can afford.
There is a Pursuit-specific section. You could ask in there...although, you might want to check the already-created threads, as I believe this has been covered.
Sent from my SM-N975U using Tapatalk
Thanks guys. And I hope as my knowledge increases I can help others along the way.
