5 Attachment(s)
A Little Disappointed with the T-180 v3 water inlet/outlet setup
I've used dozens of the v1 & v2 T-180's for FE30 P-Sport builds. They hold up, are fairly water resistant, and with a little modding of the water inlets & outlets they could be narrowed with 90 deg. fittings to squeeze the batteries in alongside for proper cg. :
Attachment 124345Attachment 124346
When I saw pictures of the v3 I was happy to think that there now can be a less fiddly (yes I watch Top Gear) mod to keep the waterlines tucked in. I was disappointed when I saw this :
Attachment 124347Attachment 124348
While it looked from the pictures that there was three possible water paths to give some configuration options, the caps (kinda tiny and no extra caps like v2) block 2 of the three possible flow-through channels. In fact to get the return line back towards the motor I'll have to change the output straight barb fitting to a 90 deg and that won't tuck in too nicely .Going to be tough to use on riggers & OPC's too...
edit : spoke too soon ; this bump on the inputs contains 2 caps
Attachment 124349
