Working with fibreglass is a wonderful thing. You can repair anything and change anything. Cutting FG or even CF plate is relatively easy with very basic tools.
Figuring out schematics and electrical can be chore tho. Haha
Muy lindo proceso de construcción:
http://www.offshore-rc.com/forum/ind...erfox-36-twin/
Soon I will try to see what it does in the water. Later I will cut the supports and see what can emerge as an improvement.
haha, yes, I'm not very familiar with electronics. I have basic knowledge. And I'm sleeping very little ...
The Silverfox comes with the mount for dual motors. Mount the motors into the mount, then align your tubes for the flex shaft before gluing in the mount. That should help with the setup because you can keep taking out the mount with the motors attached to get tubes lined up the way you like it.
Added in some Carbon fiber supports for the large canopy and mounted the battery trays. Should be ready to try when the water turns back to liquid form:bounce:
Great work. Oh you doing a single , makes life easier. There is so much room to pop batteries in and out. Nice
I'm still not decided if I'm going to use a double or single configuration in the blue hull.
The black hull should clear that tray if I want to place the 4082 motors. I do not think it does.
Attachment 156992
Attachment 156993
Attachment 156994
Attachment 156995
I uploaded the photos again. I have batteries of 6s, engines 4082 and two variators 150a or one of 240a.
I will try to install the parts that I have. I ordered a set of x442 and x442r in case I decided on a double motor. And an x440 / 3 if I go for just one.
I am finishing up my boat today as it is raining outside. What KV are you running on the 4082? I am also going 4082 on mine with the 440/3 prop. I'll post some pictures in a little.
I still have not decided if I'm still only 4082, 1500kv and x440 / 3 or two 4082 of 2200kv and x442 / x442r. I'm going to use only the blue hull (clean hull). I'm waiting for some parts.
I have thought 6s for the double configuration of 2200kv. It is what I have available.
All buttoned up. Going to try the 4082 1900kv with the 440/3 for some testing on 6s 180amp ESC. Made a windshield for aesthetics as the canopy is pretty large and this kind of helps out.
Hello, as it was with Silver Fox.
I just finished reinforcements on the boats. They increased 8.45 oz in total after the coatings in the hull and the hatch.
Attachment 159097
Attachment 159098
Attachment 159099
Attachment 159100
Attachment 159101
Carbon fiber and reinforcement work looks fantastic excellent job.
Thank you.
I wanted to know how it went with the ship and that configuration.
I haven’t had it out yet to test, I was messing with a Genesis that I did, but I will keep you posted when I get a chance to run it.
I'm going to start assembling my silver fox with a single motor ...
The unit with two motors was assembled and tested for the first time.
Very happy with these hulls.
Attachment 161802
Attachment 161803
Haven’t had the chance to even test mine, sitting on the shelf collecting dust
