How do i stop water entering stuffing box ?
Hi all this past weekend i was doing more set-up work on my 24'' 1963 version of the Miss Triftway i raised the strut by 1/4'' and greatly improved hull speed and handling after a 2 minute run there was a good 1 1/2 oz's of water in the hull i pressure tested the water cooling system no leaks. Checked the hull for cracks none to be found. Removed the flex shaft from the brass liner and re-greased the flex shaft with Mercury 2-4-C grease and ran the boat for 1 minute water in the hull sprayed up inside the cowl where flex shaft exits brass liner. Any suggestions how i may be able to stop water entering between flex cable and brass liner ? Never had this problem with any other boat ? Regards Andris Golts.
