Hello guys, acn you tell me if the procedure in the attached sheet is right or not?
Thank you so much!
Attachment 165402
Thank you so much!
Attachment 165402
If I remember geometry correctly, that looks about right to me (not trying to be a smart @$$). But it has to be parallel with the flat surface below it to be 0 degrees. It does not matter what those 2 measurements are, just as long as they are the same it will be parallel.
