What kind of speeds are you looking to get?
I sold the boat i was gettin around 48 50 on a calm day stock motor 40c 4s 5000mah , i have now move on a motley crew doing consistant 55s and very stable hull . :thumbup1:
hey MAVDRIVER if you are doing an air dam try taking a 7/16-1/2 square piece of balsa or something some what soft and epoxy the wood so it sealed or clear coat it then double sided tape in under the hull around two inches back from the front of the tunnel and then hockey tape it to . This method works awesome. with slightly larger prop and the air dam then you set up the strut and sharpen the turn fin and rudder I have been getting a consistant 52mph even in a little rougher water, it sticks on smooth or tailing another boat and running in their wake
John
