you should never use oil just soap a lot of oils will swell rubber just a note. you have to remember not all O ring are made over here some are made over there and are not as good cheep rubber will swell up
Take a dermal with a cut off wheel . Be carful and cut a line just threw the jacket from the front to rear. Then you can pry it off . If not cut a second cut and it should fall off. Sounds like u tried everything just cut it.
Thanks Chris hope your feeling better
Gary
