3 Attachment(s)
Finally getting down to completing this boat.
Let me start off by apologizing for not posting more on this build. With 3 boats going and everything else taking place this past winter season I just started running out of time.....:frusty:
The build went extremely well. Everything is 1/16 sheeting except for the top sponson sheeting which 1/32. Flotation is just 3/4 pipe wrap foam tube. I modified the front air-damn slightly, but still used 1/4 round and cut the angle down a bit more. I had to cut the sides out on the inner rail a bit up front in order to allow the batteries to fit across the tub. You will find that you will need to have everything up front as far as it will go if you build this hull with the rear wing. On the pre-balancing I found that I may even have to add about 2 oz. up front in order to hit the COG right.
I had read some other posts on OSE and one other that some were using the CPS penetrating epoxy thru Jamestown Dist. Co. Well decided to try this product and see how it worked. The standard mix is 2:1 and I also added one part of Denatured Alcohol. This epoxy went on great. It got two coats. After each coat I just used a white rag cloth and wiped it down lightly to catch the excess. Dried over night. What I was really impressed with was the sanding ability. It had barely any clogging / build up on the sanding block. It just dusted like I was sanding the bare wood. Went through half the sandpaper that I usually go through when using West System.
The finish is standard PPG Automotive paints and clear. Going to hit it one more time with a clear tonight to hit some spots that need attention. I think the biggest pain was getting the stripping put on and in a logical sequence. Anybody that has an easy way they do this, please let me know.....:lol:
The cowling and cockpit are from Mitch Dillard at HSC, along with the stacks and the driver was from Doug at ClassicHydros. A big thanks to both of these folks for all their help. If you would like any info on how I finished these just shoot me an email.
Here are a few pictures of the almost finished boat (1985 KISW). Stacks still need to be added and hardware installed. Have our 1st club race on Sunday, maybe I'll have a chance to test it out.
