Updated fellas, as suggested by Travis (kfx), the list is now sorted by MPH. If you know of anyone on here who runs the boat, let them chime in here to be added to the list.
Added a trophy system to "reward" those with their efforts in maximizing this hull. For the rest of us pansies (lol) we get zilch for anything below these two guys. Haha (Ok maybe E for effort!)
I now have a new goal. Spring/ summer will be fun!
Figure that would spark something. I bet most of you guys don't have favorable weather at the moment. 77 degrees here by the way. :)
Attachment 148361
Member: BanixJ
MPH: 63.1
Prop: TFL CNC 4714
ESC: Stock with timing 7.5
Motor: Stock
Batteries: 2x Turnigy Nanotech 5000mAh 3s 65-130C
Mods: Polished shafts
Updated!
Question for Keagan. When I run my boat again with the tp motors I'd like to remain on the list with my stock setup as it could benefit others by seeing what it can do in stock form with a few minor mods......but list my modified setup separate.
The list is sorta split in 2 already, if Im reading you right. You would join Rafael and Erroneous and still keep your factory setup on the list. By the way, I also got some TP, will PM you shortly!
Yeah I know how that goes, Zonda build on the way? Either way man, good luck, I'm sure sooner or later I'll be adding your name to that modded list.
Attachment 149787
Hit 71.2 with the new setup. I'm thinking way more in it but not with the x447s.
Updated: Chevyprerunner
Today i'm so happy! Thanks to brand new 6S lipos! My personal record has to be updated!!!!!!
Member: BanixJ
MPH: 69 (good number) but real is 68.75....
Prop: TFL CNC 4714
Motor: Stock
Batteries: 2x Zippy Compact 3300mAh 6s 60C
Temps:
Air: 21C 70F
ESC: 45C 113F
Motors: 50C 122F
Attachment 150830Attachment 150831
updated banixj
Ran mine today stock everything and got 62.2 mph.
Member: MADRCER
MPH: 62.2
Prop: Stock
Motor: Stock
Batteries: 4x Gens Ace 5500 45C
Attachment 150912Attachment 150913
Doh I missed subbing to this Thread, how did I miss it lol.
Thanks for this guys.
Brian
Took you long enough! Updated Madrcer
Hit my new record today 68.5MPH with 2 Venom 3s 50C 5200mah.
Still adjusting the Struts / lipo position, and still need to solder up some adapters to run 4 x 3s up front.
Struts were set at 2mm gap (4mm gap is the recommended stock setting)
MPH:68.5
Props: Dasbota ABC 17/14 17Deg
Electronics: Stock
Lipos:Venom 3s 5200mah 50C
https://uploads.tapatalk-cdn.com/201...5f1bf9ce7e.jpg
Updated chevyprerunner! Nice job!
Ok I'm in. 69mph this morning
Stock esc and motors
Props 447's S&b & detounged
Wolts wire drives
Struts 3mm
4 revolectrix inline
Think I could have got more but my Lake is a little short I run out of real estate and have to shut down
Another first for me, she decided to go airborne on me did a perfect cartwheel in the air and landed good side down. No damage just knocked my struts out of adjustment lol
REDLINE1 has been added. Good Job!
Finally had time to run the Zelos today with my dasboata x447 props. I hit 71.6 mph. Keagan of you want to you could leave my initial all stock run up and add the new numbers on a separate entry for a good comparison. I have a set of 1814's coming from Chris that I will be running next time to see if I can top this number. Below is the info to update if you don't mind. Thanks to Chris for an Awesome set of props!
Attachment 151406
https://www.youtube.com/watch?v=EIKn...ature=youtu.be
Member: MADRCER
MPH: 71.6 mph
Prop: x447 Dasboata
Motor: Stock
MADRACER updated! I can't keep the old entry as the list might get cluttered if others request the same thing. I'll leave it there for now until I can come up with something that reflects both speeds. Nice job man!
Understood. Keep it clean for sure.
