Seaking 180 & 130/180HV
I have tried to use the card to program each. I have 3 program cards. 1 new. On the 180 it just shows a minus sign in each window. I also tried thru the transmeter. It just beaps. I have 3ea 180's they all react the same. I plug the batt. pack in the correct slot
The 130HV the program card just goes blank.
When trying the transmeter I can get it the program to 6 cells. I need 8 cells.
Are you using the plug in hole on the right of the program card,
Also is the plug from the esc with the opened ends facing you being plugged into the far right hole on the card ?
I know it's old but any 180's around or even 120's????
