Hi all installing above mentioned motor in a 23'' mono on 4s set timing at 7.5 degrees . Would this be a good starting point or should it be set higher ? Regards Andris Golts.
Y wind 10-15 degrees.
thanks Martin i will crank up the timing . Regards Andris
