4 Attachment(s)
TFL Pursuit Anti-Capsize - self-righting
Since pictures on the site do not really reflect reality on the transom area, posting my recent delivery.
Took ~6 weeks via ocean shipping to Florida.
The good
Unlike shown on Bangggood it does have trim tabs on both sides. 1 turning fin included, not shown in my picture
Solid build, no leaks other than expected.
Stickers etc seem solid
The ugly
Manual is for the standard version but honestly it doesn't add anything I didn't know.
Servo must be a low profile version, the hull prevents mounting any standard servo. Still had to add doublesided taps to it or it would pop out.
Accessing that drive system is a PITA. First thing to do is drill a hole into the hull to access the shaft. Small 4mm hole to get access with a straight 1.5mm driver to those little grub screws is essential. I tried patiently for a week and just had it. I did add a screw with rubber seals to keep out the water. I'll remove it to get access.
Had issues getting the throttle adjust working right, use the Futaba directions and it worked.
The normal
It will need tuning as it bounces like a bobblehead on stock settings and cavitates a lot at start up. This is all at 0 degree (tabs and stinger).
Attachment 173313
Attachment 173314
Attachment 173315
