hi
Im looking for if someone who can me me some brass liner with oiler, Im willing to pay, as i've broken almost a dozen flex already :crying:
hi
If your breaking shafts an oiler is not your solution. How is the alignment or are you over powering the set-up?
Wasn't there something about the length causing problems? Some were too long
I have a PB outboard on hand and I can make you an oiler liner. I also have hyperformance shafts new in package.
Mel279 PM Sent
here's a pic of the liner/oilers
Attachment 95524
Travis
I got your pm and it looks nicely built:thumbup1:
you will need to dremel a small area for the oiler filler tube. Just line up the top and bottom then mark where it needs to be cut. Be sure to cut it wide enough to fit the solder fillet.
