Hi,:tiphat:
Is the timing on stock motor 15* ?
And has any one tried the stock motor at a higher timing ?
For less heat.
Thanks for any info.:beerchug:
Hi,:tiphat:
For less heat.
Stock timing is 11deg. I'm sure I remember fightercat saying these motors like 15deg timing
I am here: http://maps.google.com/maps?ll=52.472035,-2.153340
Since I am looking for a replacement motor, I visited Fightercat's site, he advices to set at 30*. ( on the similar out-runners) , I wonder the Venom motor should also be set at that value? The Seaking ESC is factory set @ 15*. ( The 60A ESC that Venom uses is same as SeaKing) . The highest one can go according to the instruction is at 26.25*. Any ideas?
As default they are set to 15deg but when I contacted venom ages ago they said it was factory set to 11deg.
Thanks, that's good to know. I was just wondering what settings Venom used!
