Absolutely, those things your trying are very basic but totally necessary and I can't think of why it would not allow you to select an option..... Maybe their card is restricted for some reason, but ya, i'd use a different one that's for sure.
The cards sticker HAS all the values. But when I click the button it will only do a portion of the settings.
Im going to contact hk to see if its defective or restricted.
ya, definitely not normal.......... if they restrict their card options, i'd look into getting a different one
how many cells are u hooking up to set the options? ive never had a problem with the box setting it up with 4s
4s 2 2s
well knock on wood ...I have never had a problem with my t180's or setting them up with a box....hope hk can help u out
hobbyking has been nothing but useless. GO FIGURE
Im going to try to program it without the box. Is it hard? Also how do you do it? My esc came without instructions. Shocker lol
So I figured out that they put the wrong sticker on the box. HAHAHAHA So everything checks out. Just had to use the hobbywing instructions. It told me what item 1-4 was and all the values in the right order.
Im happy now hahaha
Now just to get them to replace these bunk lipos. I sent in pics and they are telling me that they will only replace one since the other is fine... Does this seem ok?
http://pic20.picturetrail.com/VOL140.../408074794.jpg
LMake you jump thru hoops
Honestly Im just happy that my esc came in ok. (even with the wrong sticker the sent on the card)
I cant wait to try this beast
You bought a Turnigy180?
ya about a couple weeks ago
They still around 80?
Also I forgot to mention, but 3m makes a 2 part epoxy that dries clear that when placed onto the esc totally waterproof it. I run twins in my Fantasm So I took them both apart and coated them with the 3m epoxy and they are flawless..
Ya still around 80.
Can you post a link of the 3m epoxy?
They sell it here actually
oh ok thanks
That sky rc gps is in kph not mph.
I just updated my skyrc gps. It now reads in MPH, GREAT!
Did u get a gps for your Zonda yet?
Quick question I have a T180A ESC and want to replace the small aux cap bank , I have the 35v1000 caps just need to know how many to use . Thanks for any help. 4075 1800 motor / Mean Machine 5s 10000mah
Edit sorry wrong thread :(
3-UP.
When I've added caps to a Seaking 180, I just added 3. But I still left the small cap bank in place.
I simply soldered the tails of the caps to the solder points of the original caps & hold everything in place with a bit of heat shrink. Make sure to get the polarities correct for each cap though.
Here's a couple of pics.
