This was something fun and different to build. Looks cool on the water. Just need some people drinkin' some beers on deck then it'll be complete!
I love the detail, looks great mate
Thank you, my friend!
Very nice...................got any more pics???
I blew up yours so i could see it better...................:Peace_Sign:
Attachment 76379Yup, a few more.Attachment 76377Attachment 76378 And thank You!
Looks very scale!!! Great job.
how did you make the pontoons? I think this is one of the nicest pontoon boats I have seen.
Thanks, guys!
I made the pontoon logs from 2" phenolic rocket tubes. (actually 2.153 w/ 1/16" wall thickness) Then went over them with 3/4 oz. glass cloth. I left them hollow, no flotation, as anything added to the inside wouldn't do anything but add weight.
I chose 2" because it made everything easier to figure the scale out. 1"=1 foot. Most logs are 2'. LOA, from the prop to the points on the 'toons is 34". I'm guessing I have about $40.00 in it not including the EP-1 and the Tatic radio and the battery.
I made 1/8" lite ply plugs and glued the balsa blocks to them and rounded them off to make the backs of the pontoons. Then domed them a litlle.
For the front of the 'toon I used 1/8" lite ply for the keel and added 1" thick balsa blocks to each side. Shaped them on my disk sander and final sanded them by hand. Also made the 1/8" ply plugs, same as the rear. The stubby tubes they're mounted on are just to get the right O.D.Attachment 76971Attachment 76972Attachment 76973Attachment 76974Attachment 76975
Glued them together and went over everything with the glass cloth. I use 5 minute epoxy thinned 50% with acetone to attach the cloth. Let it dry overnight, sand lightly and apply another coat of thinned epoxy to make sure everything is well sealed. Then I spray sandable primer on it, wet sand inbetween coats, until it's smooth and the weave is filled.
Then it was onto making the mounts for the pontoons to attach the deck to. This took a bunch of time, but it's more scale than just glueing to the tops of the pontoon logs. (.030 styrene) plus some right angles.
Then it was on to making the deck.Attachment 77064Attachment 77065Attachment 77066
I made a third pontoon about half the lenght of the outer ones to mount the EP-1 too. Full size pontoons do this to help with the flotation for the heavier 4 stroke engines they're using. I used 1/4" aircraft ply for the motor mount with T nuts.Attachment 77067Attachment 77068Attachment 77069Attachment 77070Attachment 77071
Found a home for the servo and put the sheeting on the deck. I might add that I used the Bondex plastic cement rather than super glue. The Bondex melts the plastic together and forms, more or less, a solid joint. Where super glue will stick the pieces together ok, but doesn't bond them toether. Pieces will just snap apart. I never tried using the made for plastic super glue. Maybe that would work as well. The droplets are water from test floatin' it.Attachment 77077Attachment 77078Attachment 77079Attachment 77080Attachment 77081
I kept skipping by this thread for some reason,but now I'm glad I stopped.That is really cool work there and it turned out fantabulous.I spent alot of time on these in the Okanagan here in B.C. This looks so cool,thanks for sharing.
Shawn
Then it was on to roughing in the sides. I made these with 1/8" square styrene and sheeted them with .030" Used a heat gun to soften the plastic and formed the radius around a 1/2" dowel. Too much heat and it screws up the plastic. Not enough, and it won't hold the shape. Alot of trial and error to get it right. You can "feel" when the plastic is the right temp. Hard to explain.Attachment 77082Attachment 77083Attachment 77084Attachment 77085Attachment 77086
Thanks a ton, Shawn. Happy that you like it!
Next came the helm and some "cushy" boat furniture. The cushions for the benches were made from using 5/16 x 1/4 1/2 bulb weather stripping. Works good and has an adhesive back. A lot of "that looks about right" hereAttachment 77138Attachment 77139Attachment 77140Attachment 77141
Very good work!!!:thumbup1:
I made a couple of "life jacket" storage boxes for the rear deck. One has the receiver in it, the other one has the ESC. It's a box over another box type of thing. All the wiring is routed above the center pontoon and never gets wet.Attachment 77148Attachment 77149Attachment 77150Attachment 77151 And thanks again Make-a-Wake.
The battery compartment needed to be towards the bow and below deck. Also shows the rectangle channel for the battery wires to the center pontoon, through that to the ESC. A long lead doesn't seem to be a problem. It has room for 2 batteries but 1 runs forever. Not a speedy boat. Part throttle=looooong run times. Attachment 77152
Then I made a Bimini top for it. Used 1/8" round for the frame work. A couple of 1/8" square for the rear stationary supports. And 2 .010 thick "straps" for the front.Attachment 77153Attachment 77154
The whole boat was painted aluminum, 4 coats. I used Mono Kote trim sheets for the white and the designs. Sprayed Windex on the cut out sheet first, then "floated" them into place.Attachment 77311Attachment 77312Attachment 77313Attachment 77314 The floor (carpet) is 2MM foam stuff I picked up at a Hobby Lobby craft store. And what pontoon boat would be complete without a grill? That's made out of a fishin' bobber and some leftovers. The tables are out of pizza boxes, I guess so the pizza doesn't stick to the lid. LOL.
That pretty much covers it. Thanks for all the positive comments, guys! Attachment 77315
In-D-boat
Boy,that is great detail.And 1/12 scale? It would look good on the beach next to my scale truck
http://i1128.photobucket.com/albums/...h/Tuber002.jpg
Sorry bud I couldn't resist the pic and this is probably as scale as I possess for now.
P.S.: I love the grill and table.
Thank you! Cool truck! (Hummer?) Is that a winch on the front? Functional? Looks like I should get busy and make a trailer for the pontoon.
Nope,it is just a toolbox.I needed it to fill in the huge hole between the lights and the bumper.I don't believe in winches for the 1:1 rigs either.There comes a point when hiking is quicker.Hehe
I hope you dont mind but I am so going to replicate this and build one for myself.
Heck, no. I don't mind in the least. I would consider it a compliment. I just wish I had some plans to pass along, but I don't. Sorry. Do you have an EP-1? Any outboard heavier would probably make her a little tail heavy. (or increase the lenght of the center pontoon and lower the center some for some extra flotation ) I have some 2 1/4" tubes that if I make another one I might see about the Stilleto outboard for that. But that would be down the road some. Thank you!
