Well, when you get the gears fixed, you have some tuning to do. All that hopping is bad, and probably didn't do the gears any favors either. It's hard to say, but I would start with trim angle, tilt the outdrive down a little bit, to add a some negative trim. This should stop the bow from shooting towards the sky, then falling flat. Moving weight forward can also help, but change one thing at a time.
