is ther a link out there that walks you through the theory and process of sharpening props i want to give it a try
thanks for your help
Alex,I sent you a pm.
You can sharpen them with sandpaper.I was polishing an X450 and cut my finger twice.Have the wide open gashes to prove it.
Beryllium Copper is TOXIC, read the guide here on OSE, the link is above.
ya a good dust mask
In case you guys want to read about Beryllium toxicity:
http://en.wikipedia.org/wiki/Beryllium#Toxicity
I "sharpened" my prop for the genesis, its only a 38mm prop, and it seems okay, however maybe for under 100kmph setups it might not be as important to get the prop balanced properly, I used water and wet n dry sandpaper and some disposable gloves.
i have files and was thinking , if its easy time is nothing ill give it a shot so where can i buy a resonably priced balancer?
Here on OSE, or Kintec racing is another on line option. Your LHS or pretty much any on line site that carries RC boat products will likely have a few to choose from.
Personally I prefer the magnetic balancers, no need to level them, and I find them a to more sensitive.
Kevin
Top flight magnetic balancer 20.00 LHS seem to carry them.
I have one and it works great,
go into the tips section of ose and that will get you started.
We also have them:
About halfway down the page.
http://minicatracingusa.com/accs.html
Have a read and do nut cut your self lol:doh:
http://www.voodoopropellers.com/polish.html
Old Guy
