Batteries in cold weather
Hi guys, :help:
I am new to the forum, and been admiring your discussions from a distance for a while now. I am also fairly new to boating, and currently hold a TFL Pursuit 8s project (not finished) and started with my trusty FT011 which was highly modified a short while (back to stock now again).
My questions regarding batteries is:
Can it be true, that the cold weather (2 degrees C / 32 degrees F), can cause the LiPo's to sag so much, that the low voltage cutoff built in to most ecs, make the boat undrivable in cold waters? I could simply not get a full throttle run the other day I was trying.
My battery setup:
4x 5200mah 4S gens ace bashing
Running stock FT011
Let me know if you have had similar issues. BTW, the batteries did only stay out in the cold for about 30 minutes before i used them and experienced this issue. :confused1:
Cheers
Emil Wilkens - DK - https://www.youtube.com/user/Fyren07/videos
