Attachment 115321Attachment 115322Attachment 115323ok i would like to retract my drivers needing paint as a bad thing. I spent a little bit of time and painted them up. I did it at work so it was a little rushed at times but I'm happy with the way it turned out over all. I ran gps on it yesterday and got a max of 20.1 mph, it was on smooth water but the ride was still off, it was hopping way bad so i feel like there is more speed to be had with the stock power system.
I ran it again today with a 900 mah 3s as far forward as possible ( bow has a bulkhead that stops you from going very far) that was just in there as ballast, I stuck a 3s 4000 mah battery towards the rear of the battery tray and it ran quite a bit flatter, still needs some tuning but it was better. I'm pretty sure I can make use of the tabs I "fabbed" up. I drilled the holes for the adjustment screws a hair large so one of them is stripped already.
Here are some pics, and i'll see if I can get the video from today up.
