Sounds perfect to me. You're not getting much cavitation at all.
I'll mess with some step once spring comes
I am final putting my bj back together, it was all in a box, trying a miss g flex shaft.
Is it spring yet? I can't rember winter being this long!:cursing:
prop nut,when you moved the fins to the top hole,i take it you drilled a new hole for the lower screw,and then covered up the old old?i will have more questions about all this once i tear into it.but figured i would start with the fins
oh ok,i thought you used the existing top holes and drilled 2 more on top of that.I will go back through the posts
What kind of speeds should you expect out of the stock setup, boat was bouncing on top of the small waves, but it took a while to get on plane. I hit around 26.9 mph with 7 cell 4200 traxxas and a 3 blade prop, I am going to try the same setup witht the stock prop, I have lipos but one has a bad cell, I think.
went back out, still not really smooth, a lot of jumping around, ran the stock prop. With stock prop it got on to plan a lot easier. The first pack I ran was a new set of seven cell. Got 27 mph even, then I put the lipos in 30.7 mph.
Stock motor, stock esc, I get almost 43mph out of mine. X642, detongued and tip cup. Lipo, 40C 5000mah 4S
Detongue is removing the area close to the hub that kinda swings forward and then back to the tip. Easiest way to explain it, look at a M445 and an X445. The "M" series props come detongued from the factory. Cupping is very slightly bending the tips back and or the traling edge of the blade. That kinda describes it, its a bit more involved and easy to mess up if your not careful.
Had my boat out today, it went well until I took it to the other side of the pond and ran out of room, the front has a small crack along the seam, but I did not spilt it open, I'm sure it will get a few more war wounds before summers done.
http://www.youtube.com/user/112racin.../0/fejMrqO-fI8
I don't even think it needs to be packed right now, just a hair l;ine crack
I'd atleast throw alittle epoxy behind it so it dosent get any bigger
Is it possible for the bec to burn up in the speed control? I used my boat a few weeks ago and it worked fine, I go to use it today and nothing, no power to the speed control. the wire is hooked up. I try it tonight and as soon as I put a rx back to the reciver the boat works fine.
Mine did that and it ended up being the switch went bad.
I guess I just use a battery pack, not worth taking it all apart.
I just cut the switch off and twisted the wires together... simple n easy
true
by far my boat is running better with out turn fins
Thanks for the info, Bumping this, and subscribing as a newb.
Does anybody know where to buy a detounged x642? Thanks
Chris Hoffman aka dasboata can make one for you. Send him a PM and tell him Tom Jerzak sent you. He does great work!
https://forums.offshoreelectrics.com/...?5485-dasboata
Tom
Tfhanks tonstoys2...I will do that......
