OK is there a rule to follow when doing twin out drives?
how far apart do the props need to be?
http://i339.photobucket.com/albums/n...725975DB09.jpg
http://i339.photobucket.com/albums/n...725B9588D2.jpg[/QUOTE]
Can't help with your question, but who makes the drives and rudder? MTC?
10-4
as long as the both blades are clear of each other when spinning plus counter rotate the props .
What propellers will you use ?
If you run 45mm propellers, distance between the stingers is 47 or 48mm
http://img1.imagilive.com/0918/Image_temp_4883.jpg
I really dont know what props im going to use yet. the boat is a 59" sv-43 almost identical to the boat pictured
https://forums.offshoreelectrics.com...t-Voltaic-quot
I'm prototype my brackets so I'll have to space based on a large 70mm prop. With the 70mm mock up props I have about 8mm between props.https://uploads.tapatalk-cdn.com/201...38d3f75d58.jpghttps://uploads.tapatalk-cdn.com/201...16570342c5.jpg
Sent from my SM-G930V using Tapatalk
