CAN THE CASTLE 120 HANDLE 2 PACK OF 3 AT ONE TIME OR IS IT GOING TO HURT IT AT 20C 5000MI PACKS THANKS. ALSO WHEN RUNNING 2 LIPO PACKS OF 2 ON EACH SIDE OF BOAT WHERE DO I SHUT THE VOLTAGE CUT OFF AT ON HYDRA THANKS:help:
If those packs are parrellel then no problem, that is 11.1v nominal. Castle has expressed having problems with their controllers on 6S or 22.2v it may work if the amp draw stays relatively low, but if you're pushing the limits of the controller then it'll fry. I don't recommend 6s regardless, unless you know exactly what you're doing and are willing to risk spending another $105 soon for a replacement.
Jeff
thank you I m pretty new to hobby ul ice
