67mph?
what motor are you running in yours??
anyone have a red evo in the US for sale or the exsite
try a 440/3 or a 442/3 and do you have any angle in your strut?
in the gas one has a sikk 27 4 bolt version with porting done its got so much power now, it turns a x470/3 with ease
i have tried a x442 speed was ok but the lifting prop sat much nicer on the water
well lifting props work for some things lol ive never liked using them because i use the strut to raise the ass end up lol
i've actualy only got one gas and 8 electric but mostly cats and monos so im new to lifting props and as i tried one for the first time it ran real nice, i was impressed thats all
KOS i guess what im trying to figure out is how fast are you looking to go with your setup.
I think around 50mph should be ok thinking about using 5s and a x637, motor says it will handle 6s but i dont want to go that far
try running either a:
y536 it will lend itself to high rpms
for 3 blade the y537-3 it pretty good but needs a powerfull motor on 4S
x440 will give you big hole shoot but need a powerfull motor as well.
and the x640 is the top end prop i like the best but you better match up the motor and esc correctly or poof majic smoke from the ESC...
Last post was 9 months ago, g freak.
sporthydrofan I just bought a Miss Excite and will be using the stock motor/esc what is the best prop to get for it in a 3 blade metal prop.
I want some more speed out of it. I will be running 3s and 4s lipo's.
Joe
Can this boat handle 5s without any mods? Or what have you guys found to be the best battery set up?
She doesn't want 5s on the stock system. I have a 5s system that propells it to about 80+
http://www.youtube.com/watch?v=H4PadPAK-Ls
Great, thanks for the response. Literally at the lake about to put it in.
Hi bill,
Why you need red venom 36 mm 1.4 p prop ? I seem this item was discontinues in atomik web suite . But I seem
another one same size and pitch prop only is silver Aluminium. What's diffrence between of this two prop effect ?
Please advise ! Thanks !!
The red one may be a bit more durable, but the silver one is just fine! : )
Noted with thanks Bill . Can I asked you one more question ? I seem your miss excite is really very fast .
Did you change the motor and special setting ? If you don't mind , please teach me how can I improve my miss
Excite more speed and stable running in the lake . Thank you so much !!!
I have a Red Evo i am willing to sell.
Any master can be advise me if I change the motor on this boat . The 3650 1800 kv inrunner or H3126 2200kv outrunner motor which one is better on the speed ? I tried to put proboat 1800 kv inrunner motor in this motor mount . But this mount is too small. Any same size motor mount plate but the hole is fit 3650 size motor ? Please
advise !! thanks
