I have just sourced a HK Smash Shark and over the coming summer will do some modifications. As the hull is notorious for chine walking I intend raising the stinger mounting about 3 mm to settle the deep vee in the water. Trimtabs will be fitted and with the raised stinger mounting I assume the trimtabs would be similarly mounted a little higher to minimise drag.
Power will come from a Leopard Hobby 4074 2200kv running 4s power with a Turnigy T3 180 amp ESC.
Ideally I should strip the interior and apply a CF inlay, but after reading a little archival material, I will attach carbon fibre rods internally, covering with 50mm fibreglass tape. The troublesome HK motor mounts and battery mount will also receive a little reinforcement as detailed in the archival material. The transom inner face will also receive a fibreglass overlay.
I have sourced small trimtabs as the Smash Shark is not that wide in the transom. Also, being a little anal when it comes to sufficient water cooling flow, I have sourced a Genesis upgrade rudder with dual outlets and four pickup holes and will adapt this to the stock rudder mount.
A one-piece 3/16" flexshaft has been purchased and a Speedmaster rotating bush will be sourced to finish off the drive. Eventually a 440/3 prop will be fitted, however, for testing I may use the detongued, balanced and sharpened 442 two blade that I have or maybe a 440 two blade.
