Originally Posted by
Johnc
Ok guys first hand experience here, listen up,
Just got out of the hospital (12 days, 6 in ICU) for guess what? beryllium copper poisoning. Stupid me: got a little itty bitty belt sander just to work on the props, decided to try and see if it would work, started the sander up and touched the prop to it a couple of times. Couldn't have touched the prop more than 10 maybe 15 seconds total in different positions. Next day was calling 911 because I couldn't breath. On oxygen 24 hrs a day, 9 different meds, going to take 10 t0 12 weeks before wheezing starts to go away.
Here's a few items about that stuff:
You can build up a tolerance (but depends on your body) but not worth trying that one,
You never, never get rid of it and will get worse over time, doctors can only help you to be able to breath (steroids, oxygen, inhalers, meds),
It has been reported that it does cause cancer,
If your like me: working on the props you eventually will get a few cuts in your fingers. Well ya know what? even if you wet/oil sand and not cover up you little cuts it will get into your blood stream and end up in your lungs. So be careful about those little cuts.
Still plan on being a spectator at the FE nationals though
John
