What weight of carbon fiber fabric should I use to reinforce a fiberglass hull?
I use a standard 2x2 weave 3K cloth. It still conforms to the corners well enough. I've used multiple layers on particularly flimsy sections of some hulls, or in problem spots like seams.
This what I used
https://www.amazon.com/Twill-Carbon-...gateway&sr=8-6
You can get plain weave carbon cloth or twill, the twill is easier to use on compound curves & into corners etc. Personally i prefer twill as it stays flatter easier in these areas, plain weave can lift in these areas once wetted out with resin before the resin cures.
Yep, what I use is a twill weave. I misspoke when I said plain.
Thanks again guys. All your responses have been more than helpful.
