Originally Posted by
brad65
Thanks bro, I saw your theard and your running gear which looks good. Yes I'm running the stock running gear with octura blue plastic prop with is the same size as stock. I've own'd a shockwave 26 before and I ran a vxl system with a large metal prop which destroyed the u-joint (main reason I started this thread). I'm sticking with plastic props with stock hardware on this boat. I have a stock blackjack 26 prop which I know will make this thing even sicker but I don't think I have enough weight to keep this boat on the water plain and simple. So I'm unsure where I want to go with the boat as it sits. Do I stiffen up the hull, add turn fins and tabs and add weight to the boat then try different props. Or just drive and enjoy the boat, its fun! Speed is addicting, I went from stock motor/esc/battery to 14.4v custom sodered 550 brushed motor/16.8v esc on 4s battery to now true boat brushless powered system on 3s. Every time I'm getting faster and getting slowly used to the power and wanting more. Funny this esc can handle 6s. Humm I wonder how it will run on 4s hehe LOL.... Wow boat are fun, I hope this site gets busier.
