Questions: P-Limited Motor Connectors & Boat Balancing
Hey Guys, I have a few questions on my builds.
1.) The Aquacraft motors come with 4mm connectors already attached. Is it alright to cut those off and upgrade to 5.5mm connectors or do they have to stay to keep the motor 100% stock?
2.) I'm working on the layout of ESC locations and wanted to know if there are any opinions out there regarding the balancing of the boat. Should the boat be as balanced as possible? Or is there any advantage to having a little extra weight on the inside of the turns (right side)?
3.) Could you guys provide any advice on front to back balancing? On a hydro, I've heard its best to have the center of balance at the tail end of the front sponsor. Is there a good starting point for a mono and cat? Like right in the center? Or maybe a third of the way from the rear? My mono is a 32” Pursuit and my cat is a 32” River Cat/Apparition.
Thanks in advance for any help you guys can provide,
Dave Howarth
