I just want to make sure I understand this correctly. I have Dinogy 4S 4000mAh batteries. They have a 1-3C charge. If I want to charge them in 2C do I double the 4000mAh to 8000mah?
No change the charge current. It automatically does 1c but you can change it. It's a couple more items down past the Mah setting, set to 8 amp charge rate.
Thanks. So a 6S 5000 mAh I set to 10 amps? I appreciate your help
yep as long as your power supply can keep up.
