http://www.tomotorsports.com/image/c...Rc-600x600.jpg
So about a week ago I spotted this boat at a HomeHardware thats close to me, I did some research on the boat and it sounds like a really good deal. Its listed as 129.99 CAD but i found it for 69.99 CAD at this store. Anyways, it looks to be hobby-grade (or at least as close as you can get). Like all of the components are seprate as found in our boats and the battery even runs a deans connector (on a toy grade :w00t: ). Heres a few links:Quote:
Litehawk RC Charger Speedboat (LITEHAWK 20001)
Hit speeds up to 25 kph with the Charger Speedboat from LiteHawk. Ground-breaking 2.4 Ghz spectrum radio technology allows for greater range and control, while the Charger's twin hull lifts the boat off the water at high speeds for greater acceleration.
Product Features
Twin hull design remote control speedboat
9g rudder uses water flow technology to cool the electrical and motor parts
ABS injection molded twin hull design for a stable run, even through waves
Speeds up to 25 kph
Built to last
Fitted with stainless steel and aluminum metal and a water-resistant gasket
Remote control with ergonomic pistol grip - on/off button, left/right direction control, a throttle control stick and left/right trim buttons
Comes with display stand
Includes 4 AA batteries and one 1100mAh 7.2V NiMh battery for longer run times
Replacement parts available through LiteHawk
For ages 10+
What's in the Box?
Boat
Remote
7.2V Battery
Wall Charger
Instructions
Stand
Spare Parts Includes Prop And Allen Key
The source: http://www.thesource.ca/estore/produ...language=en-CA
Bestbuy: http://www.bestbuy.ca/en-CA/product/.../10219311.aspx
Home Hardware: http://www.homehardware.ca/en/rec/in...I7263044?Num=0
If you look at the one pic it shows the inside:
Attachment 87906
