Originally Posted by
Jesse J
If this is related to your 1/10th scale hydro fin question, you want it on the inside.. which side depends on which way you want to go around the course.
If you go conventional right turn, then you run conventional props and can use the aquacraft or any other conventional bent fins.
If you want to run more scale, like the Pacific Northwest clubs, then you would set up reverse rotating prop and fin on the port side. You would probably need to make Larry?s fin or something similar.
Placement of the rudder: I have not noticed a better side, this is probably personal preference and/or scale adherence.
Hope this helps.
