Seaking 180 esc problems
need some input on programing new performance set up from OSE, Seaking 180 esc, leopard 4082 x2 1600. I hooked up batteries and did a test, both steering and motor ran with the turn knob on Traxxas TQI. hooked up Hobbywing program card and set to the following #1 running mode =1 ,#2 lipo cells = 1, #3 low voltage = 5 3.4 cut off #4 timing 3 7.5. The turning works but there is zero response from motor? i Know the motor runs from the first test trial.
thanks in advance
Have you set the throttle range as per the instructions? I think that needs to be done for the ESC to recognise your throttle positions.
