which prop hsould i get ?
The Octura M435 and Y535 props seem to be working good for me now. I am using a Mamba max esc and a 3cell LiPo.
thanks, the m435 is on ebay, i think i'll try that
i got a new esc that can take 3 cells
any other tips on setting up the boat ?
40x52/3. I flipped upside down after the second strait away. I was glad someone with a fishing pole was able to give me a tow. The prop is made for a larger shaft so some modification is needed. I used two cut pieces of brass tubing from my local hs. inserted the small tube into the larger one, then notched the end with a small file. The shaft nut does not go in all the way so some lock tight would keep it from falling off.
The newer 3 blade 435 or whatever it is. My buds boat is fast with it.
