I just purchased this 48 inch Hydro & Marine Catamaran. The prop it came with is damaged and I need to replace it. It has a TPS 16267 motor and going to be running 5s and 6s batteries. Any help would be greatly appreciated
with this boat you need a big prop 60x size depending on the kv of the motor, and you have find out the kv for this motor ,for this hull you need 10 or 12s and a big esc( 300amp or more)
What's the diameter of the damaged prop?
That would be the easiest to start off with.
