Hey all. Hope all is well at your end with the Covid thing. I have an original skunkworks 32 cat running a seaking 180 v2 esc and a 1650 kv motor. What prop would you recomend for 6s saw speeds?
Attachment 169186
Attachment 169186
My 32" Rivercat runs on 4S, but very similar unloaded RPM to what your motor will do on 6S. With an ABC 1817 prop its gone over 100mph, in ideal conditions, hull completely dialed in, and 2 passes only. You can start with less pitch with an 1815 then try an 1816. My ESC can handle more current and has a large cap bank, so I don't recommend the 1817.
I run my 37" Genesis on 6S with a 1750kV motor using a 1915 and it does 90mph pretty consistently, but again, with an ESC that can handle more current than yours.
Thanks fweasel. Will try and 1815. I do have an extra cap bank. I plan to upgrade the motor and esc soon
Would that prop be an abc 1815 17 45?
Yes.
Ty brother
