Cooling system water flow
Question for those in the know.
Will this boat's sponson-installed water pick-ups, create enough water flow while running alone?
Or will it need electric pumps to do it.
I ask because:
1. Simple is good. less electronic-systems to go wrong.
2. TSC micro pumps are fricken expensive.
3. I got the OSE water pumps. But they are huge and bulky, and don't know if I sould run one with t-fittings, or two, one for each motor/esc (weight is adding up).
Movement induced water flow if it works, will solve a lot of my questions.
5 Attachment(s)
Steering system & plumbing
Mocked up the steering parts, and fabbed the inner shapes for the water pick-ups. The aluminum shapes will be sleeved in carbon fiber, and mounted with the stuffing-tube in between them.
Attachment 179227 Attachment 179228 Attachment 179229 Attachment 179230 Attachment 179231
