Finally, upgrade my stock SpektrumRC 9kg Servo and installed a #FANMODULE 20KG WP Digital servo, and wow, what a difference in my #Sonicwake! Plus, I am going to be installing a Seaking 180a ESC!
https://www.facebook.com/djmattpaul1...95330561363162
Many don’t realize the difference a servo can make. I up-powered a T-powered boat several years ago and when I would quickly hit WOT the boat would turn sharply or spin out. Took me awhile to figure out it was the analog servo. Even though the servo’s torque values were high, I just didn’t have control of the boat. Isn’t it supposed to be radio control? Installing a digital servo with similar specs corrected things completely, no other changes.
Digital servos have a very high centering force, while analogs do not - this is why the digital solved my control problem. That’s one reason the most powerful SAW boats use digital servos, they need to stay controlled. Too, digitals often have quicker response time, regardless of what analog specs might say. I use them on most all my boats.
It makes a huge difference! This is the one I got!
Attachment 170212
I just swapped out the stock servo for an EcoPower 110WP servo. It drives like a new boat, amazing! With the turn fits set correctly I can pull a 180* slide under power and maintain control. The servos has made the biggest performance increase out of all the mods I have tried.
I would like to know if this servo is a drop in fit as well.
