Found this on tower today, looks like the AQ mini wildcat is getting a brushless 2.4gha upgrade.
http://www3.towerhobbies.com/cgi-bin...?&I=LNBNVP&P=G
It looks bigger than the mini. I think it may be along the lines of the Rio EP. Around that size at least.
Great Planes Marine (Hobbico's boat division before Aquacraft) made a couple other versions of a boat called the "Wildcat" back in the 90's too, so this (and the mini) are a continuation of the name:
http://www.greatplanes.com/discontinued/gpmb1001.html
Should be a good entry level boat...as long as some joker doesn't try to run it on 6S the second time out to the pond because they got bored.
Along the size of the Rio would be nice. Nothing blazingly fast, just stable reliable and fun... yea there always someone that wants to slap 6s in everything... smh
Sent from my T-Mobile G2 using Tapatalk
Looks like a fun little boat. Looks ABS though...hmm. Where's Grim? I want some more info!!
Stinger9d9..
NAILED IT.. its all about getting new people excited about RC boats.. IF you are a POWER HUNGRY MARINE MONSTER!.... this boat aint for you!
I must say however.. its not all that slow!
Grim
I'm really liking these cats coming out of Aquacraft. I almost can't believe they can put out a boat with a brushless motor, a lipo capable ESC and a 2.4ghz radio for this price (about $200 with the Tower discount available from time to time). Also, remember, this boat will be backed up by great service from Hobby Services if something does go wrong - try to get service like that when buying a cheap boat from HK!
As far as an ABS hull goes, it shouldn't be a problem. ABS hulls can put up with a fair amount of speed as my brushless AQ Hammer has proven over the last couple years. Nice and light too!
It's on aquacraft's website http://aquacraftmodels.com/boats/aqu...cat/index.html.
looks kinda cool and a decent price to!
other then the twin rudder it looks like the motley crew hull
http://i433.photobucket.com/albums/q...tom/motley.jpg
i may get it if i can get the motley crew decals for it
It's 3 inches shorter and almost 1 1/2 inches narrower than the MC. Chances are at least some of the the decals (if you could get them - not likely) wouldn't fit properly.
i wonder if any one has brought one of these
2.4 radio system 1800 kv motor 50 amp speed control, all for $225 wow.
yer its a good deal i wonder if you could race with this maybe with a bit of glass reinforcement
Just picked one of these up for the wifey (and ill drive it too of course) I don't have a Rio to compare it too. But it is along the size of the ProBoat Impulse 26 I got for my dad. Will maiden her tonight. See how she stacks up against the Impulse which I converted to Brushless.
So when will this get its own section here?
Got to test out the wildcat ep out last night, and this morning I was back at my LHS returning it and picking up an Impulse 26.
To say the quality was bad is an understatement. Hobbyking would have been embarrassed to sale the electronics inside of it. After 2-3 minutes of running the motor was extremely hot, the hull was full of water thanks to a leaky hose. Half the outdated looking stickers on the outside where pealing off. The dual rudder set-up was touchy at best, any attempt to turn at speed was met with complete 180. The only points it gets is for going in a straight line, it would straight up scoot, until it got too full of water.
In general the look and feel was just not up to par with what I've gotten from ProBoat models. It's almost as if as an after thought they glued plastic sheeting on the ride pads, which in theory is a good idea, however their execution was half assed and hideous. I should have gone with my gut when comparing it to the impulse 26 at the LHS, but figured a cat would make a decently stable learning platform for the wifey to play with, like a smaller version of my miss geico.
This was my first Aquacraft purchase, and probably my last, is this type of quality typical? Or was I just lucky?
sounds like you should check over the boat and for a fact check any boat out before running it in the water.. and that goes for all users of FE boats
having a leak can be common as these are mass produced and can have a leak.. something you as the user should always check first..
and use EPA on the rudder... you won't have the 180 spin outs when you set up the rudder correctly in the radio
and the comment of a extremely hot motor?? temps bro, not just "I think its hot?" outrunners can take more heat than inrunners...
AQ made a low price point Cat to get new people into the hobby for a few hundred bucks
I would never buy from HK before AQ.. AQ has amazing service and back up there products 100%
and again this is not a $350+ boat
only about $190 through Tower with a coupon
Lets do a little thinking here brushless55. In one sentence you say I should have checked out the boat before I ran it, then you say this boat is a low price point Cat to get new people into the sport.... you really think newbies are gonna pressure test the cooling lines? And of course your going to invoke the old "these are mass produced and mistakes happen argument" way to dig deep and come up with something original. The truth is the hoses AQ used where laughable in quality.
As far as the boats control issues, let me clarify, this is not my first rodeo. I experimented, as much has one can with the stock radio, to get control in line. It either gave me little to no steering or it would become a "drift machine".
I apologize if my lack of use of my temp gun on my entry level cheap boat offended you (I'm sure all the newbies out there will share that info with you when they buy this as their first boat), but it doesn't take a genius to know that if the motor burns my finger tip...its too hot. I run 4s in the impulse brushless all day long and it comes back barely warm to the touch.
Next up lets analyze the "this is not a $350 boat" . Wow thanks for clearing that up for me, I just thought I got a great discount when I bought it for $210 at my LHS. In truth this isn't even a $210 boat id say $99 at toys 'r us clearance rack is the realm this thing lives in.
In the end you really need to relax bro. I wasn't bashing AQ in general. Just my first experience with their product, which they should be ashamed of. I did ask for input into other products they produce, which if you look at Billy Barnacles response you will see a great response in defense of AQ not just the whining bitchiness which you so graciously provided me with.
I'm sorry if my piss poor experience with an AQ product causes you loss of sleep, or heartache. It is what it is.
Man the Trolls are thick! :blink:
some just have to bash on a good company.. AQ makes great items!
and some have not a clue as to a real review...
what a :censored: joke! :frusty:
I have a AQ Wildcat EP, a AQ Rio EP and a PB Impulse 26, my obsevations: Aqucraft really need to improve the water cooling system on the motor mount of the Wildcat EP, more aluminium to aluminium contact rather than the two small round tubes.
PB have the benefit of the inner sealed "tupperware" lid which the WC and RIO does not, this inner lid is a great idea and keeps 99% of water out, even so I think taping up the outer hatch is a must; inner lid or not, you have to assume the boat is going to flip and the inner lid could become displaced during a flip.
I have found every mass produced FE boat I own needs checking over before I hit the water, you can not trust the assembly line people in the factory to get every hull right.
These entry level plastic boats are what they are and for a serious FE boater I think modications are necessary, the sloppy rudder pivots on the Rio EP and the WC really need addressing by AQ as does the motor cooling on the WC.
I find the WC and Rio EP run great with no water leaks as long as the hatch's are taped up, I have had to modify the WC motor mount to improve cooling.
Generally I find all three boats out of the box are great fun, but with a bit of modification they are better still, the Impulse 26 does seem to have the edge on hull quality and hardware over the AQ models but even so the motor was misaligned on the Impulse and the stub shaft was too tight a fit in the drive line.
I think AQ need to play catchup with PB on these entry level plastic boats and improve there quality, even so I will continue to purchase AQ products and do the necessary minor modications to give the result that I personally want.
Can we please not have another thread ruined by confrontational posts, I was hoping this thread would come online with Wildcat owners sharing there experiences with the model in a helpful way. Please calm down gents, there is nowhere to go with these kind of agressive posts, it does not help our hobby or the forum at all. Can posters please agree to disagree and call it a day.
Now down to business: I can't keep this outrunner motor in the Wildcat cool enough even with the water cooling modications I have done to the oringinal mount, I am now going to install a Leopard 2845 or Leopard 2860 inrunner 2100KV ish on 3s with a water jacket and HOR water cooled mount, I think it's a good idea but I could be wrong, what to you think.
I found the handling good but I had to turn down the travel on the rudder, my decals stayed on fine and with the hatch taped down and there was no water ingress at all. I did what you suggested, 8mm square aluminim bar with a 4mm drilled through the centre for the cooling tubes then bonded to the vertical and horizontal parts of the mount, but it still runs very hot, (too hot to touch).
It's all good Billy, I'm not that worried about Brushless55's contrived attempt at intelligence. From his reply about trolls one can conjure up a pretty good image of the guy behind the avatar of car he will never own, and in truth you kinda have to laugh at people like that. There will always be an over abundance of online know it alls, just something you have to learn to live with and from time to time address them as such and clarify issues for those seeking true experiences and reviews and not just useless dribble from the bottom dwelling (insert company name here) ball swingers.
I am glad my short review of the WC helped you out. Contrary to brushless55s short sited ramblings it was not a review of AQ as a whole, simply an experience with one of their products. In the end I'm happy I returned it and picked up the PB Impulse 26, the wifey got a couple good runs in with it last night in stock form (with no issues) now it's time to paint it pink and throw a brushes system in it.
Any and all 1st run/batch boats (and other rcs for that matter) have issues. I personally like to order the first batchs and try to figure out what is the issue and if their is one how to quickly fix. The Ul1, MG, MC all had numerous issues in the first versions I think we are at like the version 4 on the UL1 already. The MC and MG also had issues that keep the boats grounded, it's nothing against PB or AQ theses things just happen in the production versions. The prototype MC and the production MC had a few major differences.
When it comes to taping a boat, their is NO sub for that. It sucks but needs to done. Take the time and do these small things and it will save you a headache in the end, its the nature of the beast and pretty much all experiened boaters will tell you that!
Any mass produced rc product (land, air or sea) should be looked over with a fine tooth comb prior to operation. That something that you will figure out with experience. A new person to rc wouldn't know that, but like I said with experience they will.
As far as the poster about his brushless Rio, I personally don't believe it was anything against you or I think its because boat has brushlessed converted many times and the Rio section has kinda died off with all the new products on the market. I don't think anyone was personally trying to ignore you though, just maybe nothing to really add to. Just my 2 pennies. happy boating and happy easter everyone!
Wow
Hi Billy, thanks for info, I run these boats in the middle east (high ambient and high ocean temps) so water cooling is a must rather than just air cooling, the water cooled motor mount is the orange anodised 540 mount on the OSE webpage, I fabricate aluminium side plates for the mount to dissipate more heat, I have tried the coupler but I find the Octura single screw seems to work better for me, I try to keep these small plastic hull boats below 25,000RPM if I can for a more sedate uneventful drive; hence the 2100KV on 3S, as you say I run a Turnigy 60amp marine ESC, we race these plastic boats round a marked circuit in the sea (Arabian Gulf), I am looking forward to see how the Wildcat performs on an inrunner.
My Turnigy Marine 60A fits in to the mount perfectly, I believe the Turnigy 60A and Seaking 60A are the same dimensions, the width of slot in the mount is 17mm wide which can be easily opened up anyway (made of plastic), there is loads of room in the hull to mount the ESC wherever you want with whatever mount you want or just velcro the ESC to the flat bottomed hull or to the flat vertical sides of the hull.
The hole spacing on the aluminium motor mount is 19mm but this can be easily opened up to 25mm with a small round file or Dremmel.
My 60A marine ESC is the http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html your HW ESC should fit in there no problem, My ESC mounting is plastic not wood, looks like they changed to plastic on the production boats.
I have the Turnigy 60A and 120A marine ESC's from Hobbyking as the web links, they are both identical in physical dimensions to each other.
Hi Billy, here's some pics of the ESC's and the mount, I think the Turnigy ESC,s are much the same design and size of your HW unit, both of these Turnigy marine ESC's fit in the mount like a glove, it's as though they were made for each other.
I am now swaying towards the new Turnigy DLUX series of ESC's with data logging onboard, I like the idea of the large heatsink and data logging without having to have the added hardware and associated wiring, these new Dlux ESC's have a large flat bottomed heatsink which is ideal for attaching a water cooled plate or attaching to a large aluminium heatsink, I think I am going to go for the 100A dlux unit for my WC which seems to be the same size as the 55A and 70A anyway, I know 100A is a bit over the top for the WC but they are the size anyway and the price seems very reasonable from Hobbyking, my reckoning is that at 100A the ESC should run pretty cool supplying my 50A Leopard inrunner motor even without water cooling, as I have said before I run these boats in very warm climes so motor and ESC temps are my top priority.
I have gone for a very large aluminium motor mount with flat sides so I can mount the DLUX ESC straight on to the motor mount probably with a water cooled plate between the ESC and the mount, not sure how this new DLUX ESC is going to perform in a marine environment though, and I am a bit concerned if the data logging will be reliable and accurate in such a small package.
I hope the images are of some help to you.Attachment 74741Attachment 74742Attachment 74743Attachment 74744Attachment 74745
