BRAND NEW SPARTAN, RAN OUT OF THE BOX A COUPLE TIMES AND WENT INTO THE GARAGE IMMEDIATELY FOR UPGRADES.
Well shes almost complete, just need to:
1. fill a couple holes left over from original part locations
2. adjust trim tabs so they match in pitch. could use a little advice on that one. the tabs dont continue flush with the bottom of the hull at the rear of the transom as you can see in the picture. they sit up like 1/4" from the bottom of the hull. does that matter?
3. zip strip and trim the tubing back so its nice and tidy inside
4. shave down the turn fin i started on some more so its like a knife, and repeat on the other turn fin
5. attach hull seal foam around the hatch
throw'er in the water and see if she still floats and goes!
sorry i didnt get any pictures of the boat during the install. Trimming down the pieces on the interior transom to get that dang rudder assembly and bolt block installed was a SERIOUS pain. ended up grinding down the tabs and pieces of plastic sticking out that were in the way with a dremmel.
Using a dremmel to grind down a knife edge on the turn fins as well.
Attachment 133055Attachment 133056Attachment 133057Attachment 133058
