Hey all,
I'm still pretty new to RC boating, and I recently purchased and built a Genesis and am now ready for the next upgrade. Right now I'm running the stock 2050kv motor with a 150amp ESC like the one OSE carries: https://www.offshoreelectrics.com/pr...=ose-R-150C-v2 (mine is not the OSE version)
I can run on 4s, 5s, or 6s but am planning to run on 6s with the upgrade. I am currently using an Octura X445, but also have a X645 that I still have to balance and sharpen. I also feel that I may need to install battery trays a little further back in the hull.
I would really appreciate some advice on setup (which I know there's other posts), prop choice, and motor/esc size for this boat. I think I would like to be able to run consistently in the 60's, and I do enjoy doing laps with the boat over SAW runs.
Here's my boat below. I got the boat new from HK, and did an epoxy poor mixed with carbon fiber in both the tips and transom, as well as a carbon fiber lay up to strengthen the hull. I made my own motor mounts from 3mm carbon fiber sheet, and used the original aluminum motor mounts. I installed flush mount water pickups at the bottom of the hull, and also installed a Tenshock carbon fiber rudder offset, instead of the offset mount for the stock rudder. I wanted to get fancy, so I used a stainless linkage rod that fit into a carbon fiber tube for looks (and extra strength right?:biggrin:). I also installed a flood chamber style linkage boot to keep the transom looking clean. I also found a millimeter sticker that I put on the strut for easy adjustments. Since I already had the Traxxas radio, I installed a voltage sensor and temp sensor on the motor, for real time readings on the water.
Anyway, I really enjoyed building this boat, but now I need some help getting it to really move. Any and all help is appreciated. Thanks!
https://forums.offshoreelectrics.com...4&d=1557256384
https://forums.offshoreelectrics.com...3&d=1557256384
https://forums.offshoreelectrics.com...2&d=1557256384
https://forums.offshoreelectrics.com...1&d=1557256384
https://forums.offshoreelectrics.com...0&d=1557256384
