Yeah that's interesting Larry. I've been told this for years but it's not really true. You have to stick to the safety rules. The book says that failure to comply with the safety rules may result in a loss of coverage. Paraphrasing. No where does the book say "You must comply with every letter of this document or you will not be insured". I've been told repeatedly "Well, they expect us to follow our own rules". Expect? Good luck with that in court. If it's not on paper it didn't happen. Ever see cats and monos sprint together? Guess were uninsured at that point. Nonsense.
Cell counts and battery specs aren't in the safety rules. If the insurance company wanted to jam that "you weren't following the rules" thing down our throats then no event that I'm aware of since lipo was introduced would have been covered because no event that I'm aware of has ever truly tech'd the mah's. You could read the label but who knows what's under the label if you don't do a full discharge and then a subsequent recharge. Then do you discharge down to 0% before a refill to absolutely sure? If we were getting all lawyer'y, "Where's the documentation proving that you checked it?"
Checking them with absolute certainty should only take an entire day for tech for each day of racing. The only thing I check is voltage. I don't think anyone escaped scrutiny at the Cup last summer. If I missed someone I apologize. I'll be sure to check all of your crap this year. We've relied entirely on good faith since introduction of Lipo.
The whole restriction thing was an attempt to appease those that were convinced Lipo would spell the end of racing. Same response that brushless motors received. "RACING IS RUINED! WE'RE JUST RACING WALLETS NOW! THAT'S IT! I'M OUT!"
Still not sure how to address the twins thing. Larry's 6s3p twin Q cat scenario is pretty realistic and would likely come in under weight. Not sure it would be drive able but it is possible. We're planning to test a 20k single Q cat for Atlanta. See if that works. Weight is under easy.
John, I'm not sure it matters what the CD states on the flier. If a guy shows up with cells that don't have labels at all........ how does the CD know anything more than the voltage? Hmmmmm, those look like 5600 2p to me. The sketchy part would be the legitimacy of the results. For instance, one could argue that a national championship awarded to a racer whose cells were not dumped and recharged to verify compliance with the MAH restrictions is not legit. Ridiculous but you could make the argument.
Every record run is tech'd for compliance with the rules.......accept the mah restrictions because to do so is a nightmare. I've signed some record applications. I've not checked the mah. Only voltage. I doubt that the SAW guys are doing a complete discharge and recharge.
