I have a KOS P1 with a venom 2000 kv outrunner with a 120 amp seaking esc. I'm running a single 4 cell battery and was looking to upgrade to a 3 blade prop. Any help thanks.
Hi:tiphat:
I am running a x440/3 with the stock 2000kv motor and stock 60a esc or Seaking 60a esc,:sneaky2:
But I modded the setup inside and made the rudder off set to.
I was doing some testing on this boat, And some modding.
Hears a link.:beerchug:
https://forums.offshoreelectrics.com/...-offset-rudder
I run a x640 prop on mine
Do I need an adapter for running 3/16 props on this boat?
Yes,
Ose has them.
Or up grade the stock flex shaft to a .187 3/16 shaft and coupler,
That is what I have in mine.
Thanks! What parts will I need to convert to a flex cable for 3/16 props?
Get a 187 flex cable and remove the liner so it fits well and you will need to gut the stinger for a new bushing to,
The Hughey.187" cable and Etti 5mm/.187" collet would be less troublesome and very dependable,
Also will need a bushing for the stinger and a prop dog and prop nut.
Check Ose on hear or swap shop or post a WTB,
Do a search or may be rcraceboat.com or kintecracing.com
