Ummmm............ they came right off your list. :bounce:
Play nice Don. We are trying to get a good 10 years out of this discussion.:laugh::beerchug:
Never really considered a jump start an extra lap penalty. You never started.
Just because it’s on my data sheet doesn’t mean it’s a reliable motor. It was simply a data gathering exercise. I will take my chances on a 56mm AQ motor vs. the TP, Lepord, OSE Raider.... actually Darin’s test supports my preference. Doesn’t mean the AQ wins all the time, but I wouldn’t count them out along with the other 56mm motors (57mm w/bearing protrusion) :ohmy:
Whatever way you try to "limit" or level competition you have to consider tech and inspection after the race which puts an extra burden on the group holding the event. Needed protests leave hard feelings and a bad taste in general. You can mandate esc's or some sort of current limiter but that adds expense and complicates inspections. Battery size, capacity or weight still mandates after race inspection. A motor size limit is almost an easy visual by contestants and at worst done with a caliper or template. Keep it simple.
Mic
Dead on Mic.
Running the AQ is still a good option. Until some bean counter decides it isn't. Same for the Proboat motors. As much as I like the AQ, PB and even the Promarine motors............I don't trust any of those manufacturers to keep making them. Not the companies. The people that make them for the companies. We (racers) don't represent a large enough market share to influence their decisions. We've already experienced multiple design changes from Proboat and the discontinuation of multiple motors from both AQ and PB.
On the fuel limitation thing............pia. No offense Howard but we aint NASCAR. Those guys have an army of people to do tech work and every car has to pass inspection prior to racing. There is an impartial team that does that. They don't have to accuse each other of cheating for it to happen.
Same thing with an ESC restriction. Puts the onus on a racer to notice a guy might be cheating. He has to then accuse his friend of it. In writing no less. Next the contest directors need to prove or disprove it. Ugh.
We're just hobbyists here. Like minded morons getting together to play with their toys. Fer fun. You guys remember fun. Like when you were kids. This has to be stupid easy to tech. A caliper or a simple gauge tool. Done.
The battery thing doesn’t work.. again u would have to trust a manufacturers sticker.. just because said battery says 3000 mah.. it easily holds more.. I’ve never had one battery that when taken down to even 10% that when fully charged back up to 4.2 per cell doesn’t go past the amount it’s listed at..and that was with 10% left in battery...
I like Pie...
:usa:
Shoe size should be spec'd.
Yer right Doug. You know what they say. Big shoes.......big motor.
