MC/LO cooling tube kinked from factory
For those of you who are new (like me) and get a new Motley Crew beware: I just got one and after the first run I noticed it was running hot. Then I noticed no water coming out of the outlet.
The strut mount was bolted to the hull all the way up from the factory kinking the intake and outlet tubes, effectively cutting off water flow to the system. Watch out for this! Lower the mount to restore water flow, then adjust the strut to restore proper height.
Don't know if they are all like this, but just wanted to get the warning out there.
I have a Lucas Oil coming as well, and this may apply here also, will update when I get her.
Just goes to show - check you stuff before you run it!
